Deletes a peer group.
| peer-group-name | Specifies a peer group. |
N/A.
Use this command to delete a specific BGP peer group.
The following command deletes the peer group named outer:
delete bgp peer-group outer
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
